lannes
Flight distance : 4465 ft
Yes it is a GPS tracker - 3g model, the mount is a bit over engineered, you could mount it in the middle of the upper body or underside of the battery by velcro. Out of the mount the Trackimo 3g unit is quite small.
The form factor is better with the MP or MPP, which what I normally use it on, the MA and the Spark are very small so there are limited mounting points.
However you can't mount the Trackimo out the back of a MA due to the rear vision sensors.
Here it is on the MPP , it's less cumbersome mounted this way, out the back
