endotherm
Flight distance : 503241 ft
You can use a smear of blue locktite on the metal screws and use them after they have dried. Using wet loctite on plastic can cause the problem described, as the solvent attacks the plastic. There is specific locktite for use on plastic, but its use isn't appropriate here, the blue type is the correct one to use. |
