Kevjones1959
Flight distance : 61932 ft
South Africa
[size=14.6667px]Hi pilots. I cannot emphasise how important it is to understand how the RTH feature works and why it is so important to actually set it. I have heard all the "Top Guns" say they never use it and it is a gimmic feature. Well unfortunately it is not as it is embedded in the software and cant be turned off.
[size=14.6667px]The Home point setting has two options which is important to know if you trigger a return to home on a low battery for example.
[size=14.6667px]1. Return to the exact spot the aircraft took off from - this is very very accurate and the aircraft will literally land within inches of where it took off from. and Return to the controller - This is more complex and the issues with this will be discussed below.
[size=14.6667px]If you set your return to home point where the aircraft is taking off from, namely, it's GPS position on the ground, this setting MUST be done each and every time prior to take off, dont assume that the aircraft has set this. It cannot set this location without strong GPS signals. It will TELL you that RTH has been set where the aircraft is standing and request that you check in on your map.. I cant look inside the code to see if the previous location has been erased or not when you power the aircraft on again following a previous flight. I strongly recommend that you ensure that this is set before you take off. Why ?
[size=14.6667px]1. Due to the nature of RTH being integrated in the operation of the aircraft should you experience any technical difficulties with other aspects of the aircraft with a correctly set RTH you have a very good chance of recovering your aircraft. For example you are out of visual range and the camera stops working or the connection is lost.Or the battery develops a malfunction. At least the aircraft knows where it must return to.
[size=14.6667px]Home Point setting to controller. In order for the aircraft to know where the controller is, it needs to have updated positional information being fed to it. This implies that this position is being transmitted to the aircraft. What you need to be careful of here is say you have this setting set and you drive off or walk off following the aircraft and for some reason you lose connectivity you are not going to be sure exactly what the last updated position of the controller was. I am sure you can deduce the results if for instance you were on a boat and assume the controller setting has been updated.
[size=14.6667px]The home point settings work in conjunction with the RC signal lost and battery low warning however a malfunction of one of those readings can trigger this code as well. I would only use the hover function if I can see the aircraft at all times such as indoors.
[size=14.6667px]Within each one of these settings there are various parameters that you need to set. For instance the RTH altitude. Make sure you choose an altitude that is higher than the tallest obstacle around you. When RTH is initiated. The default is battery at 30%. Initially I would leave this as it gives you enough time to exit RTH should you wish.
[size=14.6667px]Once RTH is initiated you have the option of cancelling it. I strongly advise that you only do this once the aircraft is "under control" namely, you can see it, you have connectivity, the video feed is working.
[size=14.6667px]Hopefully the new pilots will get something from this post. Safe flying. |
