Stuck Batteries solved.
1046 3 2018-3-31
Oscar Myer
This morning I was reading a few posts from people who were having a really tough time taking their batteries out of their P4.  I decided to check mine and sure enough, I had a real fight with the thing trying to get it out.  So hard in fact, I almost ripped a fingernail off... blood all over.  I finally managed to get it out and decided to try my spare battery.  Same thing.
I was reading where one guy was using a ruler to pry it out.  Another guy was using a small flat head screwdriver.  I then came accross this guy on YouTube who had a P2 and was having the same problem.  His solution was to put a tiny amount of white litium grease on the "tracks" that run down the edges of the top of the battery.  When I'm saying "tiny" I'm talking a MINISCULE amount.
Well, I tried it.  The batteries came out without nearly as much effort compared to what there was before.  I still needed to use both hands but I certainly didn't need a ruler or screwdriver to remove it.
I will point out that both my batteries are DJI... not clones... one that came with the drone and the other that I ordered as a spare.  The drone hasn't flown yet so it isn't caused by damage from a crash.
And so I guess I'll keep using this solution unless someone might have better one that they'd like to share with me?
2018-3-31
Mark The Droner
Flight distance : 2917 ft
I've used a little vegetable oil.  It has to be placed at the right spot - wherever that spot may be.
Otherwise, here's the proper way and the improper way to remove a battery:
2018-3-31
Aardvark
Flight distance : 384432 ft
The video shows the correct and easy method to remove battery at the start and about 15 seconds in.
2018-3-31
Oscar Myer
Aardvark Posted at 2018-3-31 11:43
Oh my!!!  After watching the video my reaction was, Yeah. Right. Good luck with that.  Then I tried it.
Thanks so much for this!!!  There's so much to learn before actually putting the drone up in the sky!!!
2018-3-31
