m1n1s
Flight distance : 319915 ft
pop the sd-card into your mac or pc and copy the files , i would recommend you format the card using the sd card formatter which can be downloaded for free from the internet , pop your sd card back in your spark and you should be ok again.
check your sd card is at least a U class otherwise you will have this problem again. |
