Crystal Sky Monitor shut down during flight
766 1 2018-4-2
fans80029a52
Flight distance : 352359 ft
Week ago when my Mavic Pro was in the air, SC screen suddenly shot down.
I many times pushed power button, I hear click inside CS but screen appeared for split of second few times, and after that screen didn’t torn on any more again.
Ambience temperature was only 25°C, battery was charge 80%.
Thanks for Return Home button, drone safely landing .
I changed with second battery, check pins condition –everything was OK, except CS was not working.
Few days later when I check again CS, believe or not it’s started work.
I contacted with DJI support via email, & will send today for evaluation, but my point, CS must be reliable device, not reboot, or disconnect or fixed by itself.
I believe that DJI’s Crystal Sky have a serious design issue, and should be resolve ASAP.
By the way DJI one time exchanged my CS for reboot issue, and now it’s happened with another unit,
I see on the forum that I am not alone  with this issue.
2018-4-2
DJI Elektra
Hi, I think our designated department will locate the problem for you. I would recommend you post the case number here if you need help. Thanks for your cooperation.
2018-4-2
