Opinions requested on FW update.
fans50b43636
Flight distance : 26161 ft
Hey folks!  So here is where I'm at.  I was 3.1.13 in my Dji app and had gone 33 weeks without updating.  Unfortunatley I accidently hit the update button when doing some others and now have 3.1.30.  Dji updated my AC to 1.53.0+ when in for a repair.  I had left out the sd card in hopes they would leave it alone, but they updated it anyway.  When it came back I had to update the controller to its current 1.92.
Now I purchased a new battery which requires a fw update.  The firmware on my sd card was too old so here is the question.  Is it best to use and keep the 1.53.0 fw or update everything with the 1.11.20?  Anyone using 1 11.20 and happy with it?
2018-4-4
KedDK
Flight distance : 1133038 ft
Denmark
You might get better luck if you edit your OP out of 'Videos and Photos' to the section of your drone and tell what you have.
I can figure out from the versions mentioned that it is not the P4P so i can't help beside i think that if it works for you don't update but ignore the new version messages.
It might just be the battery firmware it want to update, this should be safe to do.
2018-4-4
fans50b43636
Thanks for the reply.  I was trying to post in the p3 pro/advanced area.  At any rate I decided to go all out update everything and added Litchi for good luck.
2018-4-5
DJI Susan
There will be a reminder if the aircraft and battery firmware are not matched. I'd suggest updating to the latest version and check the performance. Feel free to contact us if you encounter any further questions.
2018-4-6
Danneboyyyy
Flight distance : 664882 ft
Sweden
Hi!
My opinion is that is better to upgrade to the latest firmware if you have the guarante on the drone. I you don't have the latest update the guarante might not be accepted.
Have a nice day!
2018-4-8
KedDK
Denmark
Danneboyyyy Posted at 2018-4-8 01:23
Hi!
Have a nice day!
Warranty and updates are independent creatures. DJI should recall the drones if issues that really demand an update should show up.
Not all have their DJI equipment on the net and does not get any update messages but DJI have the mail from registration and last login from the app if they would need to make a recall.
2018-4-9
repairman
Flight distance : 16581 ft
i am using 1.11.20,works great
2018-4-9
fans50b43636
So I basically took all the current updates and firmwares and am happy to report no serious issues.  I have made a couple of test flights with the DJI app and other than the "fly wìth caution warning about interference" it worked just fine.  While flying the signal strength meter showed full bars.  The Litchi app though is fantastic and I really should have bought it a year and a half back when I bought the P3A.  It offers better maps, flight modes etc. So auto updates are turned off all around and hopefully a couple years of trouble free flying lay ahead!
2018-4-9
