lannes
Flight distance : 4465 ft
coleputt Posted at 2018-4-4 14:57
I left it connected for about an hour or so but nothing happened. As I am saying, I think I broke the tongue thing in the Micro USB charging port. Hoping this won't cost me too much.
It may not be reparable as they will need to re-solder a new port onto the circuit board.
The usb port is useless without the internal tab, DJI have caused this by not using the more more universally used micro-B port, with the edges cut off which prevents you from inserting the plug incorrectly. Instead they use the rectangular micro-A which allows you to jam the plug in and break the internal tab in the port.
You'll notice with both micro usb ports that the internal tab is orientated toward the lower half, instead of the middle, that is why the micro usg plug can only go in one way.
