P4P GL300E
51108 20 2018-4-4
goldrock
Flight distance : 2303451 ft
google services installed at last. Drone deploy can run but still no AC connection.
Getting closer dji   any tips
That wouldnt be as much fun now would it
20180405_061510274_iOS.jpg 20180405_061523308_iOS.jpg 20180405_061554453_iOS.jpg 20180405_061605701_iOS.jpg 20180405_061609220_iOS.jpg 20180405_061612806_iOS.jpg 20180405_061617259_iOS.jpg 20180405_061943566_iOS.jpg 20180405_061952869_iOS.jpg 20180405_062022797_iOS.jpg 20180405_062055008_iOS.jpg 20180405_062204172_iOS.jpg 20180405_063623257_iOS.jpg 20180405_062142643_iOS.jpg 20180405_062154434_iOS.jpg
2018-4-4
scottmargetts
Flight distance : 198862 ft
Good stuff. Hoping for some progress on this
2018-4-5
nJo-nJo
Flight distance : 51355 ft
Bulgaria
Good work. May one day we with plus controller are same like others. not 2 versions in the past...
2018-4-7
dji-spark
this is great
2018-4-7
lannes
Flight distance : 4465 ft
Is Drone deploy looking for google maps
2018-4-8
goldrock
drone deploy sees the maps ok just cannot connect to the bird. Will have another go at it when i get time.
2018-4-8
goldrock
Update. All 3rd party flight apps are now working
litchi GL300E
litchi GL300E
2018-4-9
goldrock
Hey dji. Tell the techinicians that are busy working on this issue not to worry. We worked it out. Cheers
2018-4-9
dorbot
Flight distance : 844770 ft
someone said something about using the Amazon store to get litchi and force closing all DJI software then using a usb to micro usb cable to plug the controller into itself to fool it into spawning the popup to ask which software you wanted to use. Select litch and it worked... easy.
Clear as mud.
Bwahahahahahaaaa i lolled...
2018-4-9
KedDK
Flight distance : 1133038 ft
Denmark
goldrock Posted at 2018-4-9 00:13
Good fighting, now you just have to make a nice step by step ''how to''' in the tutorial section for all the other + owners.
How much space remain on the controller, guess you have not tried expanding the internal SD?
2018-4-9
goldrock
KedDK Posted at 2018-4-9 00:26
Thanks. i had to delete a few apps like wechat to make room for google play. However, its seems you can use the amazon app now for Litchi, if thats all you need.  I will try and explain all soon but need a little time for testing  before a new dji firmware update stops it all from working.
Yes, you can use external SD as expansion if you want.
2018-4-9
goldrock
dorbot Posted at 2018-4-9 00:17
Clear as mud.
dont need to force close anything. Plugging in the usb cable spawns the popup window.  its pretty easy. even i can do it
2018-4-9
dorbot
Well I'm not buying Litchi again just so I  can run it on underpowered hardware.....If the folk who wrote Litchi gave me an amazon key or something then maybe just for fun.
2018-4-9
goldrock
your not Robinson Crusoe dorbot. Download the free beta APK ;)
2018-4-9
KedDK
Denmark
goldrock Posted at 2018-4-9 01:35
From where?
2018-4-9
FarmerMac
Flight distance : 1215079 ft
Denmark
Guide please
I can Only fint the place where to apply for being a BETA tester, but I have to
buy the official app first.
2018-4-9
AvatarAir
Flight distance : 150932 ft
Just curious but why do you have SuperSU installed. And I was able to install Google Play Services but it just quits all the time. Couldn't run anything.
2018-4-9
goldrock
super su allows you to root the device. Then install google services via chainfire & opengapps.
2018-4-9
goldrock
FarmerMac Posted at 2018-4-9 05:26
Guide please
cant remember where i found it, just search the net, its there somewhere ;)
2018-4-9
goldrock
this will give you a good idea of how it all works. Obviously a little different to CS but this is the guts of it.
2018-4-9
djiuser_mwy2kwhZiMWE
Thanks, how can we do it?
2019-10-4
