fansdda027f2
Flight distance : 416837 ft
I am having this same problem and it's the first time I've seen it personally. I was out shooting a real estate location and one video file, out of several, gives me the following error when I try to import.
I have no issues playing this same file on other players but Premiere Pro is having issues with it for some reason. I have tried installing QT, Clearing out the Media Cache folders, and everything recommended above but haven't had any luck. If I try to use AME to transcode the file, what format is advised to transcode too? This is the following information about my file I cannot import from MediaInfo.
General
CompleteName : E:\Drone Footage\2018\04-2018\2018-04-25\DJI_0055.MP4
Format : MPEG-4
Format_Profile : JVT
CodecID/String : avc1 (avc1/isom)
FileSize/String : 831 MiB
Duration/String : 1mn 10s
OverallBitRate_Mode/String : VBR
OverallBitRate/String : 99.5 Mbps
Encoded_Date : UTC 2018-04-25 16:17:38
Tagged_Date : UTC 2018-04-25 16:17:38
Comment : DE=None, Mode=M, DSW=0001
Video
ID/String : 1
Format : AVC
Format/Info : Advanced Video Codec
Format_Profile : High@L5.1
Format_Settings : CABAC / 1 Ref Frames
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 1 frame1
Format_Settings_GOP : M=1, N=30
CodecID : avc1
CodecID/Info : Advanced Video Coding
Duration/String : 1mn 9s
BitRate/String : 100.0 Mbps
Width/String : 3840 pixel3
Height/String : 2160 pixel3
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : CFR
FrameRate/String : 29.970 (30000/1001) fps3
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String : 8 bit3
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.402
StreamSize/String : 830 MiB (100%)
Title : DJI.AVC
Language/String : en
colour_range : Limited
colour_primaries : BT.709
transfer_characteristics : BT.709
matrix_coefficients : BT.709
Other
Type : meta
Default/String : No
BitRate_Mode : VBR
I hope there is a fix coming out soon. Thanks for any input. |
