Mark The Droner
Flight distance : 2917 ft
Wow.
First - the P3 4K is the name of a DJI Phantom, but that particular Phantom has nothing to do with anything in your post. I guess you have a Phantom and also a 4K camera attached to it.
It's not easy to tell in your brief video, but it appears to me that your controller is not a P3 SE controller. The clue is that the P3 SE controller has only one stick antenna. The P3P controller has two stick antennas.
I would find out for sure exactly which Phantom you have. Then I would find out exactly which controller you have. Then I would be sure the two components are designed to work with each other. For example, a P3P controller will not work with a P3 SE aircraft.
Next I would begin reading the manual for whatever Phantom you own before I did anything else, including charging batteries.
Re charging - I would charge one battery at a time. I believe this is recommended in the manual somewhere. It appears you are trying to charge the controller and the flight battery at the same time. I don't think that's a good idea.
Good luck.
