Litchi via amazon app?
3268 21 2018-4-6
mrbill
Flight distance : 633691 ft
Has anybody managed to install Litchi on a crystal sky unit yet? I saw someone posting in another forum that you could install it via the amazon app..
2018-4-6
mrbill
Found my own answer - yes!
https://flylitchi.com/crystalsky
2018-4-6
lannes
Flight distance : 4465 ft
Tried using the latest version of Litichi, you will need to buy it again via your amazon account, it's 20 usd.
When running it on the Crystalsky 5.5 it made it super hot (48c)  in a few minutes , not wanting to burn out the screen I shut it down.
The current version of DJI Go4 on the CS definitely runs cooler, so I will probably stick to that.
2018-4-6
hallmark007
Flight distance : 4724977 ft
I installed today video below if your having trouble.
2018-4-7
Pauxier
Flight distance : 1213238 ft
Does it run with go4 installed?
On my other android devices, the Litchi instructions say to force stop the DJI app.
I'm also wodering how much of a resource hog the Amazon app is.
Hmmm I think i will wait for more reports.
2018-4-7
lannes
Pauxier Posted at 2018-4-7 11:47
It does run with DJI Go 4 installed on the CS but obviously not running.
The sideloaded version of Litchi 4.0.2 (patched) in my mind runs better than the latest Amazon enabled version.
The amazon version requires you to buy another Litchi license even though you might have already paid for it in the apple or google app stores.
2018-4-7
JMR58
Flight distance : 586608 ft
The Amazon-Litchi on CS is very laggy and sometimes not responding, cause Crystalsky 7.85hb is running very hot.
Parts of the screen, squares don't fill and stay white.., missions take a while for loading and give warnings so its not safe to start..
In 'follow' or 'Track' its very difficult to give in the distance numbers, i needed some luck.., anyway for me its not useful and pity of the money!
Sometimes  on the screen "Litchi isn't responding, do you want to close it??"
Litchi support suggests to reduce the "Preview Quality" to 4Mbps in the Litchi settings,.. that's for the next attempt.
Dji apps are all force stopped before opening Litchi!
2018-4-18
hallmark007
JMR58 Posted at 2018-4-18 08:59
Same problem here , video feed is crap not able to use touch screen and app keeps asking do I want to close, something wrong with this app.
2018-4-19
JMR58
hallmark007 Posted at 2018-4-19 12:40
Double checked all instructions and Litchi suggestions, but test was again not a succes, "review Quality" is standard set to 4 Mbps in Litchi app, Crystalsky touchscreen doesn't react properly!
Send problem again to their support.
2018-4-22
hallmark007
JMR58 Posted at 2018-4-22 11:35
Double checked all instructions and Litchi suggestions, but test was again not a succes, "Preview Quality" is standard set to 4 Mbps in Litchi app, Crystalsky touchscreen doesn't react properly!
Thanks for the update. It’s unusable for me at this moment.
2018-4-22
JMR58
hallmark007 Posted at 2018-4-22 11:55
This solution from Litchi support made the app back usable on my Crystalsky 7.85hd and Phantom4.I made several testflights using Litch FPV, Waypoint missions, Pano, and Follow, they all reacted perfect in the air and on the touchscreen.
Litchi support:
Could you please try to change the map engine (from Here maps to Google maps) to see if that fixes your issues?
In order for Google maps to work, you first need to install these 3 apks:
- Google Play Services: https://apkfree.com/download/goo ... .7.44-032-173432861
- Google Play Info: https://apkpure.com/play-service ... wnload?from=details
- Google Play Store: https://apkpure.com/google-play- ... wnload/80837500-APK
Then in Litchi’s settings, change the “Map Engine” setting to “Google Maps”, the app will then restart.
If you have error popups as a result of installing the above APKs, try to force close “Google Play Services” in Crystalsky’s Settings – Apps section.
2018-4-24
hallmark007
JMR58 Posted at 2018-4-24 06:38
Litchi support:
Thanks for that I will try later.
2018-4-24
merkelck.verizon
Flight distance : 274318 ft
I waited to order my CS until I found out that the Litchi app would be available. When that happened, I ordered one of the 7.85"UB units to use with my P3A/P. I used it for three days before the display  failed. All of the Litchi functions seemed to work fine. After getting the unit back from repair, all the functions worked fine but for the voice prompts. Litchi Lucy sounds more like Litchi Larry.   The voice prompts sound fine on my Nvidia Shield.  So I don't know what they did to that thing but I am beginning to wonder!!!!
Kent M
2018-5-23
merkelck.verizon
merkelck.verizon Posted at 2018-5-23 13:14
Kent M
I got a response from Litchi regarding this issue. They claim the CS uses an outdated text-to-speech app and that causes the problem. I could care less as everything else seems to be fine
2018-5-25
FlyGuy
Flight distance : 106483 ft
Belgium
Had litchi installeren and working. Since the update of the I2 a few weeks ago I keep getting "disconnected" message. I can't seem to connect the drone and the the app. So far the app is useless. Pretty disappointed.,
2018-5-27
goldrock
Flight distance : 1893983 ft
Use "open gapps", to install google sevices/playstore etc. Then do restore so google is installed first. After that Litchi runs as it should.
2018-5-27
mrbill
goldrock Posted at 2018-5-27 16:42
[view_image]
You should do a video - I wouldn’t know how to start what you’re talking about. What’s open gapp?
2018-5-27
goldrock
https://opengapps.org/
im no good at videos ;)
There is already a lot of information out there, youtube, github etc.
I have only fine tuned it to work properly.
2018-5-27
FlyGuy
Goldrock,
App is working Alain. Thnx for the info
2018-5-28
jazzyjeff
Not quite sure why one would have to pay a second registration fee for the same application which was available on the Google Play store. I actually put an email out to Litchi to see what they say? I was told that my license was good for all devices? Lets see what happens.
2018-8-20
djiuser_nsD4cLc2HSeF
nice information
9-14 21:30
Archangel3356
Flight distance : 4007431 ft
I’ve loaded and tried Litchi on both my CS monitors a while back and always had issues during a flight. Disconnects or severe video lag and can’t remember the other issues at this point. Love Litchi on my iPad, not so much on Crystalsky.
9-15 06:11
