cameracollector
Flight distance : 807133 ft
impressiver Posted at 2018-4-7 17:32
It's hard to say without taking the cover off and seeing what happens during the startup sequence. Of course, if it's still in warranty, just send it to DJI. But since you're asking, I'll assume that's not an option.
As a bit of encouragement, all of the expensive stuff looks to be intact based on your photos. The camera housing is thick metal, should be fine. Unless the gimbal arms were bent, you might need a new gimbal ribbon cable, some new mounting hardware, maybe a motor or two. DJI will suggest you replace the entire gimbal, but good luck finding a new one. It is absolutely possible to repair with parts off eBay, for less than the cost of a new gimbal.
Thanks for the replies all. Yes I was flying past it and it looks like I hit it on purpose the way I veered into it. For awhile now I have had trouble with the P4 drifting to the right when I try to go in a straight line, this was one of those times and I was trying to slowly get back centered over the tracks. I was flying from inside my truck at the time because it was -10C out, and had just glanced up to watch it fly by the crossing I was sitting at and I thought "oh yeah that stop sign" about 0.5 seconds before it hit.
Yes it's just shy of two years old, so well out of warranty. None of the gimbal itself seems to be damaged, or the ribbon cable. Same with the motors, other than all 4 props broken and 3 of the prop mounts. The only visible damage to the chassis is the small dent in the gimbal housing as seen in the 2nd image.
I was going to take it apart this afternoon but didn't get around to it, perhaps tomorrow. |
