NFA Fabrication
DJI Mindy Posted at 2018-4-8 00:16
Hi there, when you use the gimbal GH4, please check the setting in the app, you can select APP Output Mode as 'EXT'.
And also may I know the flight controller you use? If possible, please provide us the pictures of your mounting, thank you.
Thanks for the reply, I am waaaaay past all that. I also updated the OP post with that I am using the A2 FC, I forgot to add that. I replaced the HDMI/AV module on the last gimbal as well, did not fix the problem, finally exchanged the entire gimbal, and now I don't even have tilt/shutter control like I did with the last one, as well as no video feed or visible firmware for the HD/AV module. The gimbal wont even initialize anymore. It starts to, the just stops and then does a free spin till it comes to a rest. I don't know if the problem is in the gimbal, Lightbridge 2, the A2 flight controller... The whole system was built to DJI's tutorial videos. But having an inoperable S900 since November is really taking it's toll on me. I want a professional to just look at the thing as a whole, but I think the DJI stores are all gone now? there used to be one 20 minutes from me. I hooked up the new gimbal, went in an updated all the firmwares that I could, but the new one like I said no longer initiates completely or has tilt/shutter controls working. The only problems with the last one were no video feed/visible firmware. I wonder if I forgot a step I did to get that far. This in beyond frustrating. I almost just have to part it out at this point. Everything was purchased new down to the GH4 camera... |
