Buzzyone
Flight distance : 4647913 ft
They seem to use a brushed on con coat, you should be ok, a wipe down with a damp cloth will be all that’s needed, the air is pushed through the heat sink and exhausts out the rear, there is a small airflow over the flight controller/esc pcb which is well con coated. |
