Player for 4k playback
1623 8 2018-4-7
ckloke
Flight distance : 594268 ft
Hi,
I just bought a DJI Mavic Air and captured few 4k MOV files but not able to playback using Mplayer, VLC or Qtime player. The video is very laggy.
I have also tried using 5k player but the result still same. I'm using Macbook air to view the video.
Pls help to advise any recommendations, thanks.
Rdgs,
Loke
2018-4-7
Suren
Flight distance : 8219337 ft
South Africa
What Sd card are you using. for 4k your sd card has to have a minuim write speed of at least 100mbps
2018-4-7
A CW
Flight distance : 13838848 ft
Import directly from the SD card and edit in iMovies
2018-4-7
ckloke
Suren Posted at 2018-4-7 23:49
I'm using 100mbps card and able to playback the video file on my galaxy note 8 but not on my laptop
2018-4-8
ckloke
A CW Posted at 2018-4-7 23:50
Any other alternative from using iMovies
2018-4-8
A CW
ckloke Posted at 2018-4-8 00:02
Final cut pro is the top end editor for IOS
2018-4-8
ckloke
A CW Posted at 2018-4-8 00:03
Thanks a lot
2018-4-8
hallmark007
Flight distance : 6342851 ft
I don’t have any problem playing back on 5k iMac, you might need to give it some time when loading decent processing power helps.
2018-4-8
DJI Thor
Flight distance : 13602 ft
Loke, please try to store the video in the internal storage then move it to your PC. You can also change another PC to check. If the issue persists, I suggest uploading an original video to Dropbox for further confirmation. Thank you.
2018-4-8
