VPS and active track stopped working
1525 11 2018-4-8
WynandKruger
Flight distance : 871739 ft
South Africa
[size=14.6667px]Hi,
[size=14.6667px]First time poster, long time reader.
[size=14.6667px]My Mavic Pro is doing something weird. I entered active track[size=14.6667px] and filmed for a while while riding the lawnmower (exciting, I know!). I then went back to normal flight mode and came in for a landing. When I landed, the drone just landed, without doing the usual safety check and landing slowly.
[size=14.6667px]I tbought that[size=14.6667px] it was strange so I changed the battery and sent it up again to check it out. When I went up, I didn't see the front distance radar and the ground clearance on the controller displays "clearance: - -". Held my hand under it and it did nothing, it did not ascend like it should. When I click on the main entry page, everything is normal. Vision sensor state is normal.
[size=14.6667px]Then I went back[size=14.6667px] into active track. It allows me to draw the square, but then does nothing, it does not lock on, the square just vanishes. Same with quickshots and tap and fly. Tripod mode and the rest works just fine.
[size=14.6667px]Then I thought I should try to calibrate the sensors. Before I can start the calibration, i get an error next to the button, "please reboot the aircraft". I reboot and it keeps giving me the error. Then I tried to install assistant in driver enforcement mode which solved everyone else's problem, but mine! Still[size=14.6667px] get the error. Tried on windows 10 and windows 7. I do not have access to Mac.
[size=14.6667px]I then tried to downgrade the firmware just to update it again to the latest, still no VPS nor Active track and can't calibrate.
[size=14.6667px]I tried doing a reset to factory[size=14.6667px] default, made no difference. Any advice would [size=14.6667px]be appreciated. I am stumped.
2018-4-8
DJI Diana
Flight distance : 2408 ft
Hi, I'm sorry to hear about the issue that you are experiencing. May I confirm that did your drone crash before or not? At the same time, could you please show us a screenshot of the error message? We'll look into it, thanks!
2018-4-8
WynandKruger
South Africa
Hi, my drone did have a bird strike a month ago, but no damage, only broken props. I do not get an error on the DJI go app, everything is normal. I only get an error on dji assistant. Please see attached image.
2018-4-8
WynandKruger
South Africa
Active track and the rest of the intelligent flight modes give no error, they just dont work.
2018-4-8
WynandKruger
South Africa
Please see the following video of active track, no errors, it just wont lock on.
2018-4-8
WynandKruger
South Africa
Tap and go also not working, no errors anywhere, just not working.
2018-4-8
WynandKruger
South Africa
2018-4-9
WynandKruger
South Africa
2018-4-9
WynandKruger
South Africa
Please help.
2018-4-9
DJT_MVSP
Flight distance : 2018645 ft
Try to disable obstacles avoidance while active tracking & during tap fly in sensors settings
2018-4-9
WynandKruger
South Africa
Tried to disable obstacle avoidance in active track and tapfly, made no difference. I think the culprit is my obstacle avoidance and forward obstacle sensors, as they are needed to trace the subject, if I am not mistaken. That will be the root of my problem.
2018-4-9
MarcuHaugh
Flight distance : 51030 ft
WynandKruger Posted at 2018-4-9 21:21
Did you ever fix your issue?
I've got the same problem, I can draw a box but it won't lock on.
2019-6-26
