Oscar Myer
Malaysia
Good day to all...
I fired up my DJI Phantom 4 this morning, my intent was to calibrate the IMU.
First, I turned on the RC. Next I started DJI GO 4. Next I turned on the AC. The AC is running normally. Both back lights are flashing green. Both front lights are solid red. The only thing that is responding to the RC is the gimbal, which barely moves the camera from left to right/right to left when I move the stick.
When I turn on the RC it doesn't ask/tell me that there is a FW upgrade available like it was always doing before today. As per some advice that was offered, I have not updated the FW. I'm still using the FW that was installed out of the box.
When the AC started, the camera did it's self check as it normally does.
On the top left conner of the screen the RC says "Disconnected" and no matter what I do, it won't connect to the AC. I've shut down and restarted 4 to 5 times.
Theres a message in the settings saying "Gimbal not Connected"
As I said; I move the stick and the gimbal barely moves from side to side.
I don't understand... The last time - and only time I flew, everything was normal and working the way it was supposed to, right up to the end of my flight. I did have an issue with a tree five minutes into the flight - broke 3 props and it fell about 3 feet, but after that I put on new props and took it up for another flight that lasted for about 45 minutes with no issues. I quit after this because the battery was getting low. Everything was normal when I packed it up.
I have a fully charged battery. The RC is fully charged.
I re-installed the DJI app.
I'm not sure if I have left anything out here, but if so, let me know and I'll follow up.
Thanks in advance for any help that may offered.
