DJI Susan
wleinen Posted at 2018-4-9 03:50
Thanks so much for the reply. It wasn't a crash per se, so much as it just went haywire on takeoff one morning. It never exceeded a foot or so in altitude. No wind to speak of. It would NOT land. And it flipped itself inverted like a 4-bladed ginsu knife on crack. NO idea what happened. Up until then, it had run flawlessly. I believe there is a firmware update, and I will perform that. Would it be too much trouble to explain the hard IMU reset process? Thank you again.
Thanks for the clarification. Make sure the firmware update is successful, then do the IMU calibration. If the issue remains, I'm sorry it is not available to figure out remotely, you may consider to send it in. |
