Dear all,
anyone knows if it is possible to recover also the height at which a photo/video has been recorded?
Inside exif data I am not able to see it.
if you look in the flight log from your flight then i believe it shows when pictures are taken - you can then look at the altitude in the flight log at that time. also to note that if flying over uneven terrain the height provided will be relative to your launch site height and not the height from the ground if flying higher up or lower down the hill.
Bekaru MP UAV Posted at 2018-4-10 02:58
Yes sure, thanks Bekaru, but I wishes to have the altitude into exif data, saved into photo. I will try as suggested by G_Sig
I saw that this setting is made in order to have the .STR file with all datas for videos, but...do you confirm that with this setting OFF you also have not the altitude on photos exif? Did you try that?
maurom82 Posted at 2018-4-10 07:52
Have not tested it so I went out and tested it.
You are right it don't matter.
You are using Mavic Pro? If its Mavic Air there is a tread about that.
maurom82 Posted at 2018-4-10 09:06
With video caption off I not have the altitude. I have Mavic Air..have you got a link to that thread?
If you flew the drone in a place with GPS signal, the altitude above sea level will be recorded, you can recover it when reading the image attributes.
For video, when video captions enabled, BAROMETER will be recorded. Hope it helps.
Thanks a lot, I don't understand why I was not able to see altitude data...I think I was drunk..I have no answer...now I can see it. Bah...thanks a lot for your support.
