Mirek6
Flight distance : 609724 ft
BudWalker Posted at 2018-7-18 13:58
Your sentence is entirely incorrect. It implies that magnetometer does not measure geo-magnetic filed “because it is external to AC”. ???
You're mistaken. What I said is that a calibration can not determine the properties of the geomagnetic field because it is external to the AC. In particular, a calibration can not determine the geodeclination. As I said earlier geodeclination is determined from a model based on GPS coords.
BudWalker,
I am scratching my head.
I previously said that we are in agreement - I just used words which were imprecise. Than you said we are not in agreement - misinterpreting my words and stating obvious (at least for me). Than I misinterpreted your words and so on. Let's stop please because we are confusing people on this forum. And let's not judge what is "apparent" and who knows what - you or I may be sorely mistaken - let's avoid that and let's keep it civil so we can learn from each other.
It is quite obvious to me that we both know very well how magnetometer works - we just cannot use proper words and we are just confusing each other. Perhaps language. I described soft/hard iron effects many times myself on this forum so people could understand what is going on and why it is so important to calibrate compass free of any disturbances and far away from steel, magnets, electromagnetic fields etc. A lot of people believe that avoiding magnets is all you need to be weary about.
Now - as far as agreeing to disagree. We do disagree wrt re-calibrating after travelling. Let's stop at that. You don't calibrate because, based on your knowledge, you believe it unnecessary. I do, because, based on my knowledge and recommendations from DJI, I choose additional insurance. Is it always necessary? It is not. Is it wise? I believe it is.
As far as the case of Nilesh. If he were starting from the point with magnetic interference (let's say reinforced concrete) we would see discrepancy you noted (you said about 25 degrees) but this discrepancy would become smaller and smaller as Spark was raising up away from magnetic disturbance source (compass would slowly "unwind"). Such situation could confuse Spark.
I did observe this discrepancy (not sure about 25 degress, but yes, it was there) you noted but interpreted it differently. During first 12 seconds of AC raising it was difficult for me to interpret data because Nilesh was changing yaw while flying forward. This was changing direction of flight and, within such short time span and with his movements back and for and with Spark inertia you cannot deduct much.However, once he stopped changing yaw and AC kept flying forward and raising, I can see discrepancy quite clearly. But this discrepancy does not go down. It keeps constant until, eventually, Spark gets confused.
Hence I do not agree that the root cause, in that case, was interference at the ground level. I believe the root the cause was un-calibrated compass which did not show magnetic north correctly from the beginning and constantly, throughout the flight, until Spark's firmware could no longer tolerate that. Spark's commanded position consistently differed from physical position during flight forward and Spark needed to compensate all the time. At some point it just gave up. That's all.
Mirek
