Bashy
Flight distance : 2354357 ft
Horizon can be adjust manually if needed any way, so can yaw for that matter
I checked mine again yesterday, about 8ft from the ground it was fairly straight, about 10m it veered to the right, this is nothing to do with the camera because i am watching the P4P itself and not through FPV, having said that, i then aligned the gimbal guard across the front and could see the gimbal was in fact out a few degrees to the left, so i manually adjusted the yaw and checked flight again at 10m, still veered to the right, didnt think the camera played a part in my issue.
Side note, when adjusting the yaw on the gimbal, pressing either way (clockwise/anticlockwise) a couple of times makes the gimbal go back, press left once, twice, then a 3rd and it will go back to where it was or just off, damn, hard to explain lol sod it, going to make a coffee, as you were.... |
