Using Litchi on P4P +
1222 15 2018-4-11
seapony 7
I may have missed the answer I'm looking for, but has anyone with a Plus version successfully flown with Litchi?  I've read posts about installations, but not about actually flying with it.
2018-4-11
rexster
Flight distance : 2740 ft
I did yesterday after installing Litchi using Amazon Appstore. Use the steps listed on here and it should work for you as well. Only thing I noticed was the screen was laggy with the video. I'm gonna start testing different 5.4 channels to see if it makes a difference
2018-4-11
seapony 7
rexster@nwcable.net Posted at 2018-4-11 14:43
Thanks!  I've been holding off taking the dive before seeing some reviews.
2018-4-11
AdZaM
seapony  7 Posted at 2018-4-11 15:07
I flew 3 Short Missions Today, All with 15 plus Waypoints some including instructions including Start & Stop Recording. All performed flawlessly, as instructed.
As Rexster has observed, I have also had issues with Latency of laggy live video, I did changed setting to the lowest possible ie: 4mbs, I believe the std is 6mbs. At 4mbs the video was still laggy. Even when not recording.
I did force stop DJI Go 4 on a fresh restart. I did only check 2.4ghz on Auto.
The live video is laggy enough that In my opinion you can't use it for General Flying.
After watching back the Recorded video, The cinematic video that can be achieved is fantastic.
With the laggy live feed at this point  Just sit back and watch it do its thing. Just not from the screen.
The other anomaly is that the back of the controller seemed to get much warmer than usual, This I believe could be due to the piggy backing of the USB ports of the same device, Although the App seemed a bit laggy when trying to change Shutter, Iso, Apeture settings, Although these buttons are quiet small on the built in screen. It could be that my finger wasn't quiet hitting the buttons properly. But seemed to be a delayed response when changing shutter speed for instance.
Would appreciate if others could comment on App responsiveness......
2018-4-12
seapony 7
AdZaM Posted at 2018-4-12 01:22
Thanks for the info.  I'm wondering if perhaps the monitor is lacking the power to smoothly run Litchi.
2018-4-12
SM-17
Flight distance : 179285 ft
It's not the monitor that runs litchi on the plus controller but the cpu/gpu
It's an rk3288.. Google it.
2018-4-12
KedDK
Flight distance : 1133038 ft
Denmark
Notice that DJI has released a new version for GL300E today, not sure what has been fixed but found one new bug so far.
2018-4-13
goldrock
Flight distance : 1893983 ft
KedDK Posted at 2018-4-13 01:13
2 possibilities, they have either succumbed to the fact that we can now run 3rd party  FLIGHT APPS and have released it to the masses, or, it is a patch that will stop us from using 3rd party FLIGHT APPS?  I hope its the former. Just downloading it so i can have a look
2018-4-13
dorbot
Flight distance : 844770 ft
Fixed some bugs......
That could mean anything, lol.
Big download. More that 800 Mb.
Perhaps a nice surprise, probably not.
2018-4-13
KedDK
Denmark
goldrock Posted at 2018-4-13 01:51
Hoping for the former but expecting the latter, so far i have experienced one new bug and posted it on the release thread that for some reason is not sticky so not so frequent visiting customer can see it.
2018-4-13
Latanzi
Flight distance : 839885 ft
I downloaded the other day and ran a simple 12 way point mission. Bird flew well, real time video laggy as Rexster already pointed out. My actual footage was pretty crap too, but am sure that's me not adjusting settings.
2018-4-19
Latanzi
Latanzi Posted at 2018-4-19 20:34
Feeling a bit silly!
Was trying to play back video through a card reader, transfer speed was the issue.
Great video result in the end. Have quite a bit to learn here but Litchi with P4P+ is working well.
2018-4-19
Walleye
Hello Rexster,
I was finally able to figure out, download and install Litchi on my P4P+ monitor.  As you could probably tell, I'm dumb with technology...How do I force stop DJI on the monitor so I can run Litchi?
Thanks!!
Walter
2019-2-11
Walleye
Latanzi Posted at 2018-4-19 22:46
Has anyone used Litchi Mission Hub and brought the created mission over to Litchi on the P4P+ monitor?  If so, could you describe how that is done?  Thanks!!
2019-2-11
Walleye
Walleye Posted at 2-11 15:56
Hello Rexster,
Thanks!!
After some digging found how to force stop the djig4 app.  Is that really necessary when running Litchi?
2019-2-12
Walleye
Walleye Posted at 2-11 19:42
Digging around litchi, when creating a mission on Hub if saved it can be opened from the app after logging in. It’s automatic. That’s nice.
2019-2-12
