New T-Motor CF Props - Help
771 3 2018-4-12
snath
Flight distance : 5045295 ft
Need your help, I did not see any detailed instructions on the T-Motor foldable props for the Inspire 2, I bought a set of 4 Props.
Here is my questions:
Which props go where, there is a R / L in both boxes, the way that the props are setup currently is as follows:
Front right (white).    front left (red)
Back right is (red)       back left (white)
So which T-Motor prop goes where? If I setup based on the verbiage on the prop I sense it may be wrong based on how the prop fins are configured
Should it be criss crossed where I identify right props as white and left props be left
Hopefully, I have articulated correctly
Thanks in advance
2018-4-12
TruGreen
Flight distance : 621909 ft
mount your stock props and match up the new Tmotor props to match the blade profile.
the blades are supposed to be criss crossed as they spin differently. one front spins clockwise, whereas the other front spins counter clockwise. same goes for the rear
2018-4-12
snath
TruGreen Posted at 2018-4-12 09:17
Thank you this was very helpful and simple
2018-4-12
TruGreen
snath Posted at 2018-4-12 18:29
glad to help
2018-4-12
