Woe
Flight distance : 4129268 ft
hallmark007 Posted at 2018-4-13 04:32
So having tried newly optimized APAS, it definitely climbs higher. Tested a 2 metre wall from 8 metres distance, started Aircraft at 1 metre height flew towards wall aircraft climbed 1.2 metre to clear the wall, before it would have stopped dead on approach, also tested obstacle from 6 metre obstacle 3 metre high 2 metre wide, aircraft at 1.5 metre height it flew comfortably around obstacle both forwards and backwards.
This is an improvement, Aircraft did slow down but kept moving forward with full right stick elevator, warning beeping continued until aircraft was clear of obstacles and normal flight speed resumed.
Thanks for the update, going to do some test today. |
