Wellsi
Flight distance : 8330187 ft
Jyunte Posted at 2018-4-14 00:39
EXP stands for Expo (Exponential). It doesn't change the speed, it changes the ratio of input (stick) to output (movement of the aircraft) over an exponential curve. Simply put, when the numbers are small, small movements of the stick (input) around the center position have minimal effect on the movement of the aircraft (output), but, as you move the stick further away from the center position, the output (aircraft movement) increases exponentially. This means, slight movements of the stick caused by lazy/shaky thumbs won't have much effect and won't ruin your shot. As you move the stick further away from the center position, the aircraft yaws/climbs/descends/crabs approaches the maximum rate faster and faster. This has the effect of smoothing out the controls, as you say in the video, by making the aircraft less responsive to small sick movements.
This is exactly correct, and I chose my words poorly in the video. I meant how quickly the movement starts when you move the sticks. As you say, the EXP settings change the output versus the input of the sticks (so with a lower EXP value, a slight touch to the sticks results in less movement); this is what I meant when I said in all cases for EXP, you want Less Output for More Input.
The Yaw Endpoint is what controls the overall speed of rotation.
Cheers
Ian
EDIT: See comment below; video re-edited and re-posted. Cheers, Ian
