Smart Capture
875 3 2018-4-13
GazFromBrum
Flight distance : 38606 ft
I've noticed that after using Smart Capture camera setings have been changed and not returned to original settings.
Shutter speed is moved from manual to auto
Frame rate is moved from 25fps to 60 fps
is this normal or should the settings return to original settings after exiting Smart Capture.
regards
Gary
2018-4-13
DJI Diana
Flight distance : 2408 ft
Hi Gary, it is normal, thanks!
2018-4-13
GazFromBrum
DJI Diana Posted at 2018-4-13 17:21
Can I suggest then that its recommended for future updates to return settings to previous amounts when exiting Smart Capture.
2018-4-14
GazFromBrum
Diana
Having checked the manual.... it states that Smart Gesture will record at 30fps..... this is not the case.... so is manual wrong who is software incorrect on the Mavic Air drone which records at 60fps in Smart Gesture ???
2018-4-17
