Robothamster
Flight distance : 51135 ft
hallmark007 Posted at 2018-4-18 02:25
Just a few things, when starting up MavAir, are you starting it up at the site you intend to fly from, some people start their aircraft in cars houses etc and walk to the actual site, this will result in getting compass error, also are you actually putting your aircraft on the ground then and only then starting both RC and aircraft,
I have noticed with Mavic Air that unless you actually start at take off location that you get compass error move or calibrate.
when starting up MavAir, are you starting it up at the site you intend to fly from? Yes
also are you actually putting your aircraft on the ground then and only then starting both RC and aircraft? Yes, apart from obviously you have to be holding the Air as the on button is underneath.
I don't have a smart watch, and have no metallic objects nearby apart from my Titanium wrist watch.
