Mavic Air asking for compass calibration before every flight
123
64621 109 2018-4-13
Hercules1
Compass Calibration Issue. I got my Mavic Air a few weeks ago and I am having a major problem trying to calibrate the compass. I have done the latest updates as of 09 December and I also calibrated the IMU which says Normal. When I go outside to calibrate the compass, It does the horizontal fine but the Vertical will not calibrate at all. It keeps saying Atti Mode and aircraft will not start at all. I just went through a bit over a year with two XIRO V drones that after the update on them I could not get them to start no way no how. A crap pair of drones and the company was no support at all. I sincerely hope I am not going to have the same problem with DJI. I have heard nothing but rave reviews. Frustrating when the only time I can get to try and get them going is a Sunday and you cannot talk to anyone at DJI. Anyone out there on the blog have any ideas what is going on with my Mavic Air?
2018-12-9
ManuCH
Flight distance : 157881 ft
Switzerland
Same issue for me: I have a Mavic Air and I'm on the latest firmware (.0500). Everything else is also up-to-date (iOS, DJI Go 4 app).
About 2 out of every 3 times I turn on the Air, it will ask to calibrate - but only on the first flight of a day. Subsequent flights after calibration will be fine on that same day.
I have taken all the precautions:
- far away from any cars
- without wearing a smartwatch
- remote/phone not nearby
- not turning the Air upside down when switching it on, and holding it as close to the ground as possible while pressing the power button
I was thinking about having it replaced, but after reading from others in this thread that a replacement drone (or even 2) didn't solve the issue, I think I'll just keep it that way.
2019-1-20
HereForTheBeer
Flight distance : 5381368 ft
ManuCH Posted at 1-20 22:55
DJI needs to update instructions I submitted a complaint formally about this.    But easy to resolve.
When calibrating follow step 1.  Rotate the drone flat and lever in your hand.  But ignore step 2.  Instead for part 2. point the drone so camera facing the sky and spin it aroun  With it aimed up
2019-1-21
Anthony8858
Flight distance : 9711 ft
I'd like to add..
I've also had the calibrate issue.
IMO, I think a big part of the problem is turning the MA upside down to power up.
I've now learned to position my finger on the power button and keeping the MA in its upright position before powering up.
Hit the button, then place on the ground making it my business not to tilt the MA.
Since doing that, I never get the compass error.
2019-1-24
TheVegeta1974
Flight distance : 1186296 ft
Try turning your battier on before inserting into the drone n Make sure the Craft is > 10ft from metal
2019-1-24
HereForTheBeer
Anthony8858 Posted at 1-24 03:34
I'd like to add..
could always try my instructions  i was dealing with almost every other flight needing calibration and no solid pattern as to why.     but since calibrating my compass differently (way you used to calibrate dji drones) the error has not appeared at all for me in several weeks.
when doing calibration via app, folow step one, then ignore step 2 telling you to tilt the aircraft sideways, instead turn the drone so pointing up and down and camera facing thr sky then just spin it in place counter clockwise.   since doing this my compass hasnt complained one time! and it used to complain every flight or every other flight sometimes midflight :/
2019-1-24
Anthony8858
HereForTheBeer Posted at 1-24 17:14
Yes, I took note of that and will do that........ as soon as I get the error message (which you just know I'll get at my next flight )
2019-1-24
HereForTheBeer
Anthony8858 Posted at 1-24 17:23
hopefully it works out for you.
2019-1-24
Anthony8858
HereForTheBeer Posted at 1-24 17:32
Do you think the same applies to calibrating the P4P v2?
Haven't gotten any errors, but if I did need to calibrate the compass, should I point camera upward as well?
2019-1-24
jwishbone
Flight distance : 88914 ft
I'd like to add..
That's what I do, power on with bottom of drone facing ground and immediately set it on ground and let it sit for 15 to 20 seconds or so.  Then I power on RC and wait for green light.  Then open go4 app.  This has reduced calibration requests by over 90 percent for me.  Hope this helps someone else.
2019-1-24
jwishbone
jwishbone Posted at 1-24 18:42
Sorry, meant to reply to post #84.   New guy mistake.
2019-1-24
HereForTheBeer
Anthony8858 Posted at 1-24 18:13
i would think it should work, but i dont have a phantom to verify
2019-1-24
HedgeTrimmer
HereForTheBeer Posted at 1-21 01:14
Have to give your step #2 a try.
Possibly, no more Pirouettes in work boots.
2019-1-24
HereForTheBeer
HedgeTrimmer Posted at 1-24 22:34
hopefully it works, its worth a shot!  been working out beautifully for me, haven't had to recalibrate since doing it this way!
2019-1-24
fans6a3d436c
CHSDrone1 Posted at 2018-4-20 04:14
Thanks everyone for your input.   Just to update this thread DJI technical support asked me to send the drone back to them for repair/replacement.  Hopefully my next Mavic Air unit will not have the same issues.
Hi, did dji told you what's wrong with your drone when they received it? Did they sent you a new MA or the same one? Thanks
2019-3-24
Tupungato
Flight distance : 44350 ft
Poland
I've had my Mavic Air for 5 months now. I bought it from official DJI refurbished distribution. For first few months it asked for compass calibration a few times (visible red warning at the top of the screen in phone app). I calibrated and it was OK for next 4-5 flights. Now, regardless of how and when I take off, I need to calibrate (almost) every time. I start from wooden boardwalks, stone platforms, beaten ground, large cloth towel on a sandy beach. Sometimes I calibrate the compass, do my flight, land to change the battery and fly again and it wants to be calibrated again.
Should I try to exchange it?
2019-12-12
David J.
Flight distance : 1231385 ft
For me, as others have said, it usually prompts me when I try to start up near my car. Other times though it happens for no apparent reason. Better safe than sorry I guess, but defiantly gets annoying.
2019-12-12
Rob Hilts
90% of the time I can not fly the drone because of the issue that DJI won’t address.
2019-12-22
Guillo10
Flight distance : 413 ft
Argentina
Sigo con el problema, alguna solucion ¡¡?
Saludos
2020-1-10
vixbeegmail.com
Flight distance : 29127 ft
Mexico
Same issue here, it keep asking me to recalibrate just the first time of my 3 batteries, I have the MA red one but before that I tested a black one from costco and I remember that just was calibrated only on my first flight.
I'm using Iphone 12 (IOS)
I will try:
1) turning on the MA on face down
2) calibrate it facing it up
3) update firmware and factory reset
I'll keep you posted
2020-1-20
geigy
Flight distance : 456381 ft
Late to the party here. I finally fixed my Mavic air after 2 years of recalibrating the compass nearly everyday. I did this by degaussing  the drone.
I used an old videotape degausser and held it about a foot away from the drone so it just barely caused the drone to vibrate for about one or two seconds.
After that the drone flies normally and I have not had to do that compass dance anymore.
If you decide to try this fix, easy does it. Hold the drone in one hand, unfolded, and with the other hand hold the degausser far from the drone, and bring it in slowly until you are just barely able to feel the vibration.
2020-4-25
djiuser_SURtc832VKXr
Flight distance : 12858 ft
This is super annoying - literally every time I reboot my Mavic Air it requests I recalibrate it.  Regardless of where I am - I have been in open fields, golf courses, beaches, no metal in site and this problem persists.  This has even kept me from flying the drone in several occurrences.  Is this only a problem with the Mavic Air?  As I read on people state they did not have this issue with other DJI drones.  What is DJI doing to correct this issue?  It appears a lot of people are having the same problem being there are over 8,000 pages in this thread.  For the price i paid for this drone I would expect it to work perfectly.
2020-7-8
fansa7b1cca5
I too have a Mavic air which needs calibrating every single time I take it out.  I’ve been and brought Mavic Air 2 and other than the very first calibration it’s never asked me to do it since I am probably up to my 50th flight now. That sort of ruled out any magnetic interference because I fly mainly in the same places. I would like to sell my Mavic air but I feel uncomfortable even put it up for sale knowing that they would have to calibrate it every single flight.
Andy. UK
2020-12-21
Fly_Hazr_Air
Flight distance : 56588 ft
Solucki Posted at 2018-6-7 12:01
No electronics or metal of any kind on me, I even leave my phone with the RC when I turn it on.  I do have titanium in my ankle tho. :|  Could that be enough to trigger it?
I hear this guy might have more metal in him than you do.  Make sure you don't operate around this guy!
2021-3-22
Fly_Hazr_Air
This seems to be a big problem, but looks like this guy tried degaussing with good results.  See details below.  Good Luck!
2021-3-22
Guillo10
Argentina
Hola
Alguien logro solucionar el problema de la brújula  en 2021 o 2022 ? jjajajajaja
Saludos
2022-7-8
carlose71
Argentina
Guillo10 Posted at 2022-7-8 11:55
Hola
Hi, I used the two techniques mentioned above in combination.
1- In step 2 of the calibration I placed the drone facing up.
2- I ALWAYS turn it on with the battery down.
For now, after testing with my 3 batteries, it has not asked for calibration again (it requested it in all cases).
I will try to keep you informed of my later experience to tell you how it went.
Greetings
Carlos
2023-7-25
SlammedZero
Flight distance : 3419 ft
I've been having the same issues with my drone. Reading through this thread though, it did come to my attention that I flip my drone over a lot to insert the battery/power it on. I may have to try to avoid doing that and seeing if that helps.
2023-7-30
Vofas
Flight distance : 200853 ft
Russia
SlammedZero Posted at 7-30 16:57
This should in no way affect the need for recalibration.
2023-7-31
Guillo10
Argentina
Hello, does anyone solve this calibration problem on the drone at the root?
without the solution being to change for another hahahahahaha
Greetings
2023-8-15
123
