QuadKid
Flight distance : 482349 ft
You can start the motors using a CSC command, Hold both sticks down and to the center, this will start the motors without taking off, same to shut them down. Once idling push the left control stick forward ever so slightly, this will increase rpm, if it lifts off normally then you have an issue with auto takeoff in the app. I never use Auto Take off, good practice to start the drone using CSC and let it warm up for a minute or untill you have the Homepoint updated.
BTW, you never want to use this command while flying, only for starting and shut down after landing, it is used for emergency shut down while flying should the need arise.
