hallmark007
Flight distance : 9827923 ft
Hi kfloke looking at your log , it very much looks like you took off with very little or no gps, no long or lat is recorded on your log, so its impossible to know what kind of location you were flying in, although you were trying to make some stick movements when flying without gps stick movements should be always 100% because you are fighting the drift of your aircraft, in this situation you should always try landing as soon as you can.
I suspect your aircraft went to ATTI mode and just drifted on the wind.
You should contact dpi support and start a case.
Good Luck |
