hallmark007
Flight distance : 9827923 ft
GDL Posted at 2018-4-17 04:04
That's not the first time I lost control to my Mavic Air. Another case is with iPhone after 13 minutes flight. The aircraft is 38 meters high and less than 30 meters away from me. I switch off sport mode and turn on APAS for landing. At this time the 30% low battery warning appear. Suddenly the aircraft is not responding to my stick command. The video and data link has no problem but the aircraft just not moving regardless I move both sticks to any direction. I can only press the Go Home command on app to call it back and it did respond in this time. After the aircraft fly back it also response to my stick command again. I wonder this is caused by issue of APAS system. There is no obstacle near the plane and it even not move to the side way as I commanded. Here is the flight records for checking.
http://www.phantomhelp.com/LogViewer/FXTBBQ1XA8N1AFMOV5AG/
It doesn’t show any disconnects on this log, it also doesn’t show switching to apas mode, I’m not sure if this is normally show, in logs.
Also missing any RTH . Maybe this is the wrong log. |
