de-Stefan
Flight distance : 5410 ft
Good Morning from Germany,
im having the same problem. I cant see the bars in the wifi-menu and I CANT SWITCH TO 2,4GHz. Its needed to be conform to CE.
I wont fly with 5,8GHz betwen controller and Spark. The Distance-Range in 5.8GHz is feelable shorter then with 2,4GHz.
Is there any solution to fix the problem? The firmwares are the following:
Spark: 01.00.1000(AC)
Remote: 01.00.0600(RC)
DJI GO 4: 4.3.12
Smartphone: Samsung Galaxy J6 (2018) - Octacore CPU + 3GB RAM
And would ist be possible to allow to edit the image styles (Contrast, Saturation, Sharpness) ? It would be great if i can edit ist. The images from the spark are a little bit oversharped.
Thank you very much,
Stefan from Germany.
