Punchbuggy
Flight distance : 483166 ft
Dmitry495 Posted at 2018-4-16 07:14
I'm using iPad mini 3, but, unfortunately, not that disciplined to create backup copies of the whole device.
I've read recently on the forum that all new updates of GO 4 become more demanding to processing capacity, so the older devices do not keep pace with the requirements. Kind a sad story, I hate to think that mini 3 is that much outdated
Sadly you're correct - the A7 CPU (shared by both the Mini 2 and Mini 3) is too underpowered to run the latest versions of DJI GO 4 reliably, despite what DJI advise. Even my iPhone 7 heats up now - and it runs an A10 !! The issue is the processing required by the app to perform the video decoding. That's why you could have a strong signal, but the vision still glitches or drops out - it's the iPad CPU not managing the load for the video stream.
Litchi doesn't make the same processing demands being a leaner (and I suspect more efficiently coded) app, so it may be an alternative to updating your iPad. However, there's been a number of releases of Litchi since I was running it on a Mini2, and now I've upgraded to an Air 2 anyway, so I can't categorically say it's still fine on the Mini 2/3. |
