Spark falling like a rock
1314 13 2018-4-16
fans0e6461dd
Flight distance : 359170 ft
Hello,
Two weeks ago my DJI Spark fell randomly from the sky.
According to my logs, 2.4 meters high. According to my experience, 4-5 meters high (maybe because of the inertia). According to DJI repair staff : 1.2meters. (totally not true)
DJI Repair people told me I "installed the battery wrong".
I want to ask : How can I install the battery wrong????? I just put and click the battery like the 200 times I did before.
And even more. Is DJI Spark built that way? That you can "install the battery wrong" and the drone falls from the sky a while after taking off?
DJI, do you know what I think? I think you're trying to avoid responsability.
I spent 1400€ in two sparks and now you avoid responsability for 90$....
I dont care about the 90$, but I think its not fair at all that you tell me "it's your fault"
If your drones fall from the sky, take the responsability please.
Thanks
Angel
ps. should I put glue on the battery everytime i install it?
2018-4-16
Malakai_UK
Flight distance : 536115 ft
Yet another battery related incident? How long before someone gets hurt?
2018-4-16
El Diablo
2018-4-16
DJI Susan
Angel, we're sorry for the troubles. I managed to get your case number and checking the exact status with the right team. We'll come back soon.
2018-4-16
DJI Susan
Update: We've reviewed your case again, please kindly find the data analysis result as below:
1.The aircraft was controlled by the pilot in GPS mode.
2.When T=76s, the aircraft took off. The pilot moved throttle stick upward. At T=79s, H=1.2m(only three seconds after take-off), the aircraft powered off and crashed.
Conclusion: The drone powered off within 3 seconds after take-off which indicated that the battery was not properly installed at that time.
The data analysis is based on the flight log in the aircraft, the height mentioned here is the relative height and VPS height.  According to the data analysis result, I'm afraid that it is not a warranty case. I'll attach the screenshot for your reference. Should there is any further question, feel free to contact us.
2018-4-16
fans0e6461dd
DJI Susan Posted at 2018-4-16 05:48
Hello Silvia,
I have two things to say and, so far, I didn't get an anwer from DJI.
FIRST : Why, if your drone chasis have a mistake on which the battery JUMPS out the drone, you still avoid responsability. Is it MY FAULT your Spark chasis error?
SECOND : Why, if my logs say 2.4m and my seigh saw 4-5m, you still have 1.2m on your logs. Is DJI app lying? Are you lying? Because, believe me, I'm not.
Thanks,
Angel
ps. honesty is the best business. And treating good and with honesty your clients
2018-4-16
DJI Susan
fans0e6461dd Posted at 2018-4-16 06:22
Hello Silvia,
Just to verify, has the drone been involved in the crash or hard landing before? Could you help us confirm?
Second, could you kindly offer the flight record of the accident and the screenshots you mentioned? We'd like to forward to our engineers for further review. Thanks!
2018-4-16
fans0e6461dd
DJI Susan Posted at 2018-4-16 19:47
Hello Susan
How can I download the flight logs if I dont have the drone?
I don't know how to do it
Thank you
Angel
2018-4-17
fans0e6461dd Posted at 2018-4-17 06:02
Hello Susan
I belive what Susan needs is the flight records which are saved in your APP. Here is the tutorial video for your reference:
2018-4-17
fans0e6461dd
DJI Mindy Posted at 2018-4-17 21:23
I belive what Susan needs is the flight records which are saved in your APP. Here is the tutorial video for your reference: https://www.youtube.com/watch?v=brKQZ-gTBXg&t=1s
Ok, Done
Looking forward your answer
2018-4-18
fans0e6461dd Posted at 2018-4-18 01:02
Ok, Done
Please PM me your DJI account and the accident date, thank you.
2018-4-18
fans0e6461dd
DJI Mindy Posted at 2018-4-18 01:18
Done!
Angel
2018-4-18
Hi Angel, I have replied your PM, please check, thank you.
2018-4-18
Hi Angel, our analysis team has double analyzed the data, as for the height you mentioned, it is measured by the Barometer, while the barometer is able to be affected by external air flow and temperature, it is normal if there is any slight difference.
Per the flight data exported from the aircraft, the aircraft power off immediately after take-off, which indicated that the battery was not properly installed at that time, the warranty service cannot be provided, thanks for your understanding.
2018-4-19
