KlooGee
Flight distance : 16783757 ft
Hmmm, that is interesting. Is that the last log that is on your device? You mentioned that it was flying, then dropped, then recovered for a bit, then dropped again. Just wondering if there is a log for the bit of time where it recovered.
I would definitely suggest opening a ticket with DJI support as others have already mentioned. My guess is that they will likely want the logs from the aircraft itself in addition to the flight records from your phone. If you don't already have it, you will likely need DJI Assistant 2 on your computer in order to retrieve the black box data logs from the aircraft.
Please keep us in the loop as you go through the support process. I personally haven't seen a case similar to the scenario you describe. |
