TONTOS
Flight distance : 71916 ft
Vyborny83 Posted at 2018-4-17 10:11
Ok, so I've tested the newly released DJI GO 4 and here are my results. I've tested DJI GO 4 4.2.12 build 557 with a Spark firmware 01.00.0900. DJI Assistant claims this is the newest firmware.
First the good news, OTG really displays the essential flight data again. Now the bad news, I can't see the the info about the WiFi channels (how much interference there is for each of them) and I am unable to force the RC to switch between the 5,8 GHz and 2,4 GHz band. It doesn't matter whether I use the cable or go on WiFi only connection. It simply doesn't work at all. The only way how I'm able to see it is when I reset the WiFi of the Spark and connect to it directly by phone. It connects via 2,4GHz and I can see the channel info just fine. I suspect it has something to do with the fact that my phone can't use the 5,8Ghz band but we will need more people to test it out. I'll include some screenshots below.
I am on 4.2.12 i see all my chanels and interference but did not try to change a chanel ill test and tell you |
