new here, so wen i start my drone i get this message, somthing like this it says.
push forward for 3 sec and hold C? then the bottom of my screen has a big light blue line saying somthing
yup, it shows up after it the i turn on the motors and push up a lil bit, its like some setting but i can not find nothing about it, or whats it for, so i always cancel it out.
I believe that could be the fixed wing mode. If I remember correctly, this message will always come up each time you start the AC until you tick the box to not show it anymore. For fixed wing mode, you have to push the stick forward to achieve a proper speed. Once achieved you need to press the C1 button.
So this is not an error message, just a flight mode. Next time just tick the box below the description to avoid it coming up again.
Marian Posted at 2018-4-16 22:36
YES, this is what it is, what is this mode for tho?
It is kind of like flying your drone like a plane. Instead of left and right just moving to the left/right, it "banks" like a plane does when it turns. So, at an angle (to the horizontal).
The same for up and down. It is more like climbing and diving in a plane, than just moving straight up or down as you do with a quadcopter like the Mavic.
The Mavic does all of this by keeping the gimbal fixed, which helps to give you that "flying a plane" feeling that you will get.
