JulVdev
Belgium
Hi,
I have a Matrice 100 drone and I need to connect 2 devices to it, fortunately there is 2 UART_CAN2 ports available on the drone. The first device is a SabreLite and the other is a Raspberry Pi 3 B+. When I connect one of the 2 it works perfectly but when I connect the 2 at the same time, one doesn't work. I got this error on the raspberry pi side :
Read App ID
User Configuration read successfully.
STATUS/1 @ init, L55: Attempting to open device /dev/ttyUSB0 with baudrate 115200...
STATUS/1 @ init, L65: ...Serial started successfully.
ERRORLOG/1 @ getDroneVersion, L1339: Drone version not obtained! Please do not proceed.
Possible reasons:
Serial port connection:
* SDK is not enabled, please check DJI Assistant2 -> SDK -> [v] Enable API Control.
* Baudrate is not correct, please double-check from DJI Assistant2 -> SDK -> baudrate.
* TX and RX pins are inverted.
* Serial port is occupied by another program.
* Permission required. Please do 'sudo usermod -a -G dialout $USER' (you do not need to replace $USER with your username). Then logout and login again
ERRORLOG/1 @ activate, L1228: Unable to initialize some vehicle components!
STATUS/1 @ getErrorCodeMessage, L644: initVehicle
STATUS/1 @ getCommonErrorCodeMessage, L710: ACK_NO_RESPONSE_ERROR
Vehicle not initialized
Everything listed in the possible reason cannot be the reason sinnce the code is working as soon as I remove the SabreLite. And for the Serial ports used, I've used each UART_CAN2 ports so I assume they are different ports. The 2 devices don't use the same version of the OSDK, maybe that's the reason, is the UART protocol used by the drone dependent of the OSDK version?
