B1houdini
Flight distance : 927927 ft
FlyDK Posted at 2018-4-17 11:19
The extensions give no problems as far as I can assess. I've flown with the same kind of landing kit on my own MP for some time now - I'm still doing it and will keep it that way. It is fair to mention that I never fly quite far away from the controller, so if it can reduce the effect over longer distances I don't know.
A little tip: I've had more than one set of these extensions, but lost one or both of the front legs during flights. The solution was gluing with some kind of silicone adhesive. The glue never cures up to hard but stays as a durable, soft and flexible mass that makes it possible to remove the legs from the drone again. The rear extension sits very well on it's own.
I fly with the Landing extensions on all the time. Don't believe they would cause an interference problem since they are not a metallic item.
FlyDk, thanks for the tip on holding on to the leg extension. I lost one and had to buy a new set.
