DJI Susan Posted at 2018-5-11 00:42
It is normal to get this warning in the thick cloud or moisture weather, or close to trees. If not, I'm afraid that it might be concluded as misinformation. We will optimize this issue in the next firmware to avoid similar confusions.
BTW, I've read your another post and will reply later. Thanks for your patience.
Hi Susan
the other day i was up to examine a bird's nest in a pear tree for eggs and chicks to make sure it was safe to take away, when i had this error popping up again, so you're right that it happen when close to trees but why does it show when i have the sensors disabled?
When disabled the sensors is supposed to be inactivated, specially a sensor like the ultrasonic that can result in different disturbances to other equipment and bother animals!
Please have your engineers make sure that when a sensor has been deactivated it really is!
UltraSonic sensor error even OA is disabled, indicating the Ultrasonic is still active!
