DJI Diana
Flight distance : 2408 ft
Bokepacha Posted at 2018-4-19 05:36
Hi DJI Diana!
Why is that? Nowadays batteries and chargers are intelligent and stop charging once the cycle is complete. I'd understand that leaving a laptop or a phone connected is an extra stress for the battery, because both are in use. Mavic batteries are not in use so once the cycle is complete and they are 100%, the process should stop and never charge them again.
Hi Bokepacha, I do understand your concern, so sorry for the misunderstanding. Yes, the batteries and chargers are intelligent and stop charging once the cycle is complete, you can leave them at night charging while you sleep, there is no negative effect on the batteries, please don't worry. It is just a recommendation and not so alert. Personally, I won't plug the charger into the wall all the time. It doesn't matter to charge the batteries when you are sleeping, you can remove the batteries when you wake up. Thanks! |
