Front lins , take it of ?
fans5bc86a63
Flight distance : 87749 ft
Sweden
Hello , I have a DJI PHANTHOM 4 Advanced and i want to remove the front lins , so I can put another filter on
Is it possible to unscrew the lins ?
2018-4-19
msinger
Flight distance : 228255 ft
Yes, you can unscrew the stock UV filter that comes installed on the camera. Grip it loosely with even pressure around the filter and turn it counterclockwise.
2018-4-19
fans5bc86a63
Sweden
msinger Posted at 2018-4-19 03:27
Perfect , I was scared to destroy it
Thank you for an fast answer
Have a great day
2018-4-19
fans5bc86a63
Sweden
it is stocked ... dosent move a inch
2018-4-19
fans5bc86a63
Sweden
2018-4-19
ALABAMA
Flight distance : 10442687 ft
These at very tricky to remove and can be damaged in the process. The key words, like msinger mentioned, are loose and even. It's kind of a "feel" thing.
2018-4-19
fans5bc86a63
Sweden
ALABAMA Posted at 2018-4-19 03:44
thanks , i been watching videos on youtube , its possible , but you need to me gentel , no pressure , just , twist it
2018-4-19
Bashy
Flight distance : 2354357 ft
Lick your 1st and 2nd finger and thumb, rub together, put finger and thumb at 12, 6 and 9 oclock (like a triangle shape) and with the lightest of pressure you can do,  twist it anti clockwise, if it does not move, you are squeezing too hard, touch it light a feather, its soft material and any pressure puts it out of shape a little and makes it grip and it cannot turn., softly, softly, catchy monkey lol
2018-4-19
DJI Susan
I'm sorry there are no many skills on unscrewing the filter. Just make sure the direction is anti-clockwise.
2018-4-19
fans5bc86a63
Sweden
DJI Susan Posted at 2018-4-19 22:15
Thank you , still no sucess , sorry , this one feel like its glued
2018-4-20
FatherXmas
Flight distance : 4058619 ft
fans5bc86a63 Posted at 2018-4-20 12:12
Do you have a tie wrap? Some folks have had success gently tighten a tie wrap around the lens and use the tie wrap tail as leverage.
2018-4-20
fans5bc86a63
Sweden
FatherXmas Posted at 2018-4-20 12:29
God bless you Fatherxmas , i will try it
2018-4-20
Bashy
If my method above didnt work then you are pressing/squeezing TOO tightly, you will not believe how gentle you need to be, the lightest touch possible before your fingers slip off.  On your lappy or mac book, using the mousepad, try to move your finger on it without moving the actual mouse, no matter how lightly you touch the pad, the mouse moves, well, the touch of the lens cover needs to be like that. Problem with the lens cover is, the tighter you squeeze, the harder it becomes, if you have an elastic bands? double the single band and place around the lens and same applies, lightly touching, lightest touch possible,  twist that mother off there...
2018-4-20
DJI Susan
Sorry about this. You may ask a local experienced pilot for help to see whether there is any luck.
2018-4-23
fans5bc86a63
Sweden
DJI Susan Posted at 2018-4-23 04:15
I got it now... i have to realy force it
But now I can change lins
2018-7-4
DJI Susan
fans5bc86a63 Posted at 2018-7-4 21:26
We're glad to hear this. Do not forget to share your works with us.
2018-7-7
