Bekaru MP UAV
Flight distance : 15513100 ft
South Africa
nywrecker Posted at 2018-4-19 15:05
If I move the outer edges closer together I eliminate the begging and the end of the clip.
What I want to do as an example is get the first 10 seconds, skip several seconds, get another few seconds, etc. In essence how do I get non contiguous footage?
ok - so you insert the clip and make the first edit where you desire, say the first part of the clip.
Then you will clip the + button to add another clip - at this point you will then enter the same original clip again and edit that to the piece you desire (lets say a middle section of the footage.
And then if you wish to add another segment of that original clip you will press + button again and enter that same footage again and using the slide bars reduce it also to the section you wish to use.
