Rvrrat14
Flight distance : 655932 ft
Find a large OPEN field with little to no obstacles, interference,, etc. WIDE OPEN.
Start in P mode and fly around a bit. Notice the winds; direction.speed.
Locate the bird upwind of you and hover about 20 ft off the ground. Switch to ATTI. Notice the drift. Glance down at your display and notice the speed the bird is drifting. Compare to your wind speed you found during preflight. Slowly try to maintain your hover in location. Once you can do that, begin small rectangular patterns in front of you. Expand to circular patterns. Fly as much/as far/close as you’re comfortable. When things get screwy, switch back to P to stop and hover. Bring the bird back to your position and begin again, switching to ATTI. My landings are in P mode. I don’t practice this in Atti, and feel if I have to land it, I can. May not be pretty, but I can get it down.
Good Luck.
