NedUK
Flight distance : 555262 ft
So firstly I know ultimately I’m to blame its my drone and I chose where to and not to fly before world war three breaks out....
Had a little incident today but was very interesting how it happened and something to learn from.
Found a loverly piece of land down in Dorset and thought I’ve gotta get some photos. 1 attached
This was the photo take just before the crash. All flying well not to close to the trees and very confident in what I’m doing.
Battery was getting low so thought time to come home, interested to see how close to take off point it can get and wanted to start packing up so hit the return home function.
RTH Altitude set to 20 meters thinking this was more than enough, but as the photo is taken I’m situated just to the left of the photo along the road about 150 meters away with a tree between me and the drone as you can see. As soon as the drone received its return home command I expected it to raise up and come home but it turned left and flew into the tree, I got a overload warning on a motor and it disconnected.
A quick 150 meter run to the area with fingers crossed all the way and I’m stood under the tree thinking where do I start as there is some over grown areas.
Drone reconnects but no real useful image at this point so I cringe worried about further damage and press the take off button and just to my left I hear a little beep and a whir as it decides then stops take off to say can’t take off.
So there’s my spark perfectly sat after it’s at least 20 meter fall nicely in a lovely little bed of dry leaves.
I’ve got a scuff on 1 rear prop, a rear prop missing but not a single mark on the drone or gimble.
Got the drone home, new props all round just in case, test flight and all is good no issues at all.
So lessons learned
1. Make sure the RTH altitude is sufficient.
2. Don’t trust anyone to fly your spark, not even the RTH
Questions though......!!!!!!!!!
Shouldnt the drones front facing sensor have picked up the tree and changed the path of the Spark. Hence the light hearted "whos to blame"
Secondly maybe you can and i dont know how but is it possible to make the drone beep from the remote ? could be handy
All in all no harm done and good lessons learned.
If you made it this far, thanks for reading
