Hello Everybody
I have a question regarding latest FW update and distortion on my setup ( X5s + DJI stock lens ).
After last FW update, I've noticed my footage has extensive barrel distortion.
I can see it both on video from SSD and SD and DNG stills imported to LR.
I know you will have some of it with the wide stock lens but it wasn't as bad as now.
Did I'm missing something in the settings?
I just checked the Raw Therapy and it looks like the lens profile is not applied in LR too ( even that is show it's there )
Can anyone advise me why this is happening ?
Its exactly the same on all video formats + stills, looks like the files doesnt have any lens profile at all.
So as there was no clear guidelines what this might be I tried few things myself and I was able to fix this.
Dont know what was causing it but re-update of FW resolved this problem.
Still don't know why no profiles were applied before but everything came back to normal now.
Crio, sorry for the late response, glad to know the issue was figured out by yourself, we would need the original pictures for analysis, please let us know if the issue persists. Thank you.
Crio Posted at 2018-4-22 10:25
I have exactly the same problem. I’m using the Olympus 12mm lens and have the same distortion in ky sills and video. What did you do to solve this problem?
Tegels Posted at 4-26 12:02
I've done FW update again and I've reset all camera settings.
It was some camera module glitch as it wasn't applying corrections to DNGs ( lens profile to straighten the horizon, remove vignetting etc...)
