JerryLaurence
Flight distance : 21988 ft
DJI Mindy Posted at 2018-4-22 23:40
Hi Jerry, solid error means battery error, when you plug the battery into the aircraft, is there any error message in the APP? The new firmware has optimized the cell voltage balance, are you running the latest firmware?
Hi Mindy,
This happened with three batteries after updating the firmware. The aircraft will not power up with these batteries as they are fully discharged. However, when I press the batteries’ status button I get a single flashing white LED. They have all done fewer than twenty charging cycles. |
