G_Sig
Flight distance : 9109311 ft
Iceland
djiuser_SrrIUWy2ZhDK Posted at 2018-6-19 11:51
G.Sig,if I put a sd card,will it really be ok?Will the other photo options appear again?But,I have the same issue with or without a sd card.At first all the other options did exist,then I put a sd card,they dissappeared.I took it of but the issue is still going on.
Faulty SD card and no SD card have the same affect (just single shot).
As Localeyes say software will limit pictures to save space and transfer speed.
You should first reset camera to standard settings and then try to format the card in camera.
I use 8, 16, 32, and 64 GB cards from Sandisk Lexar and Samsung and all work well. |
