Phantom 3 STD with new Samsung Galaxy S9 Plus?
2872 16 2018-4-21
EricThoren
Flight distance : 27116 ft
Sweden
Hi,
Just upgraded my phone to S9Plus, but it won't show the camera symbol in the app (I am using the app "before 4").
I startup as usual, and I can connect to drone wifi but in the app it only shows "How to connect" instead of "Camera view". It works with an iPad I have. Sure, I can fly, but I canät record or use the map or anything...
Does anyone know what to do?
2018-4-21
Amateur Droner
Flight distance : 6411 ft
Try uninstalling the DJI Go app, and then reinstall it .
2018-4-21
EricThoren
Sweden
Thanks Amateur Drone, I tried that bit it didn't help...
2018-4-21
WD9EON
Flight distance : 686886 ft
Sure sounds like you are not connected to the Phantom Wifi, but to your home Wifi.
2018-4-21
EricThoren
Sweden
WD9EON, Yes, I agree, but I really am connected to Tthe drone wifi. Well, at least that is what the phone shows.
Had a short conversation with DJI support, but they only said that S9 isn't supported.
2018-4-21
AlanHd
Flight distance : 797365 ft
Have you tried lower the screen resolution.
2018-4-21
EricThoren
Sweden
AlanHD, I hade not tried that - but now I have. Still no conection.
2018-4-21
Peterx
Flight distance : 1499708 ft
Are you sure that no other device has a down link to the Phantoms WIFI at the same time as the S6+ ? The copter system of the P3S has 3 IP addresses,the RC´s IP as the router,the AC´s IP as the client 1 and the free IP for 1 mobile in the same time as client 2. Do you use the phone in airplane mode?
2018-4-21
EricThoren
Sweden
Peterx, thank you. It's a S9+, not S6+, but yes I'm sure no other device is linked to the Phantom at the same timme.
The wifi name that appears on the phone to connect to is the same as it is when I link to it from any other device so it looks ok.
And no, I'm not using the phone in airplande mode. That would not permit me to have gps med maps while flying.
2018-4-21
Peterx
Before you fly or on the way to you flight field your phone can cache the map in to the Go app and you can switch your phone into the airplane mode short time before you power up the Phantoms system.
The GPS is still active. Only you need start WIFI manually. The map will scroll automatically to the field of flight. It´s equal using an android or iOS device.
2018-4-22
EricThoren
Sweden
Peterx, thank you - I didn't know that!
But most important - putting the phone to airplane mode did the trick! Now I get the camera view and all is well - THANK YOU!
I can even go back and disable airplane mode once being connected.
But how do you cache the mapp into the Go app?
2018-4-22
Peterx
On the last meters you can start the App on your phone and ignore all things for the flight. Close the app to the back round task. The map will be cached in that time before the phone has been switched to the airplane mode. Allow the Go app has access to your GPS in phone,then you´ll get the right area of your birds flight.
2018-4-22
DJI Susan
Eric, thanks for keeping us updated. Nice to hear the issue has been figured out. As for map cache, you can zoom in and zoom out the place you want to go when the internet is available. Then disable the internet to check whether the map works well.
2018-4-24
EricThoren
Sweden
Peterx Posted at 2018-4-22 05:41
Perfect, thank you
2018-4-24
EricThoren
Sweden
DJI Susan Posted at 2018-4-24 00:16
Thank you Suzanne!
2018-4-24
EricThoren
Sweden
EricThoren Posted at 2018-4-24 03:12
Thank you Suzanne!
Sorry, I meant Susan!
2018-4-24
DJI Susan
That's all right! Do not forget to share your works with us.
2018-4-27
